cereb6
Been looking at buying one. Not sure if it is worth it or not. Anyone have experience with pedal commander? I have heard mixed reviews about it. Is there anything else you would need to run it? Thanks.
Why? Whats the difference?Pedal monster's is WAY better IMOP.
PC will not disappoint!
Use it on Sport 4 +4. No it doesn’t add HP, just uses what’s there and gets your launch off faster.
Same here..no issues at all.I’ve had my PC31 on the truck for months and not one issue.
One important thing to note, do NOT change or adjust the settings while you are driving or touching the accelerator pedal. Only change the setting or turn it on when stopped and not moving, or in park.
I think many people who end up having engine check lights come on, or worse have tried to change the settings while driving along, change it to sport plus when they want to show off or start ‘racing’ someone on the fly. This changes the voltages the controller/computer in the truck sees and triggers an error in the system, causing problems.
I have ONLY changed settings on mine while parked or stopped and have had not one engine light, limp mode, or any other issue what so ever, so far after installing my PC and I have it on every single day to and from work, casual drives, it makes the truck feel so much more responsive, and I personally am completely satisfied with it.
This is why you should always read the manual, understand how things are supposed to be used, and not go off half cocked like a cowboy and just ‘figure it out’ as you go.
I just saw an interesting video on Pedalmonster that, if correct, would explain my PC's failures. Granted its a commercial for their product but it makes sense that the PC powering itself off of the 5v from the gas pedal circuit could be forcing the 5v to drop by overloading it.What is better about it? How much are they?
That's debatable. I had mine throw my truck into limp mode 3 times. The first was on the highway at 75 mph while in the left (3rd) lane, NO warning. VERY dangerous situation, lucky I didn't get in an accident. Same thing has happened to others in the forum. I wouldn't recommend it.
