performance chip settings...
ram5.7hemi
N/A
N/A
what should the shift points and rev limit be? its a daily driver so i don't really race it.. i step on it every now and then. but what are normal shift points and rev limit?
08 ram 5.7 hemi 4x4 quad cab Laramie
cold air intake, throttle body spacer, dual exhaust. bully dog GT gas chip
91 octane tune...
i am currently running 91 tune... what would the benefits be if any to running a lower tune?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Running the higher tune with the correct fuel will net you the best power and MPG. For your current mods you will not really see anything adjusting the rev limiter.
R
ram5.7hemi
N/A
N/A
ok, thanks. i have been running a premium tune with 91 octane. 91 octane is the highest i have seen in my area. the other tunes it has are stock and regular which don't deliver as much power.
will the 91 octane give the best MPG?
the bully dog also has a driving coach, one setting as an acceleration setting you can select low, medium, or high.... does anyone know the difference between these?
