I'd say all of it if your going to do your bumper as well. If not leave the inserts chrome.
I would reccomend pulling it all apart and doing the grille frame black and then leave the fins chrome and see how you like that
Should be 2 bolts on the top and then alot of plastic tabs that lock it in place. I think thats how mine was
Yes, this is right. Once you get the grille off, the inserts have multiple tabs that snap onto the grille. They can be a pain. You have to keep the first ones from snapping back onto the grille as you move on to the next ones. I used 2 or 3 plastic trim sticks so I could leave one or two in place while I worked with the third to unsnap the next tabs. Just be patient and you'll get it.
do the fins/inserts come off the frame do you know? so I dont have to worry about taping that off
I see that they come apart somehow, but I just can't find how to take the grill off. can anyone give me some instructions
4 screws up top across rad support the Phil top out and gently pull the bottem of the grille it's just clipped in
I removed the grill assembly and took off the emblem. I just taped the fins. Not to bad to do.
