Please don’t fall off
Chadp0517
Houston tx
Why when i hit a small bump in the rd in my 2006 dodge ram 1500 does it feel like i hit a major pothole and my tire are loose& wabbaly and gonna fall of ant mini feel like they are wabbling and gonna fall off when driving. With in the last year it’s had new wheel bearing front and back tie rods inner and outer ball joints spindles rear diff front and back shocks and just got a rotate and balance last month
rule18
Admin
NY
2017 Rebel
When did this start (after new front end components, after the recent tire re-balancing?) Are you offroading and caught a component on a rock?
Does the wobbling stop right after you hit the pothole or does it last longer? I would start simple, are the tires over-inflated?
Next, I would inspect all the steering components & shocks. Check and re-torque everything to spec. If you had the replacement work done at a shop, take it back for inspection/re-torque.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Jack up the truck so the front tire is just touching the ground. Then grab the top of the tire and push/pull back and forth hard and see if you hear a clunking. If you do your ball joints are either shot or need grease if you have greaseable joints. Repeat for the other side. That and worn shock mounts or blown shocks is what it sounds like to me.
