Please help. I’m new and this may be the wrong place
Roman_78
Evansville
this is just cranking out fluid. My buddy says it’s the ac. But I’m not sure. It is just spitting tons of fluid. Am I missing a hose? Sorry I’m just a 21 year old guy. I just got this truck. It’s mine not my parents. So any help would be appreciated
audiophile
5.7L
Can you give some more info? Engine size and maybe a wider shot for reference.
R
Roman_78
Evansville
Sorry 5.7 hemi. I cannot actually get a better shot of it because of where it is. It’s located driver side where the engine bay meets the cab. It comes out from the cab.
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
Can you take a pic further away? I want to see where those connectors are located, I see the small tube at the bottom you are talking about but have no reference point.
The Ac drain line is located on the passenger side of the truck I believe.
R
Roman_78
Evansville
Ok let me snap a quick photo. I’m in a zoom meeting til 7. Thanks for all the help
NJMOPAR
Older and faster
ELizabeth, NJ
That's the computer on the passenger side firewall. Check the two heater hoses that run along the valve cover and up to the firewall, they're right next to that area.
If it was your AC it would be an oily mess, that looks more like dried coolant stains.
R
Roman_78
Evansville
Ok so what does that mean?
NJMOPAR
Older and faster
ELizabeth, NJ
You may have a leaking heater hose. What kind of 'fluid' is it spitting out?
I'm guessing coolant, if it was freon it would blow out in 30 seconds and be empty (and your AC would blow hot)
Dodge 1500 4X4
Rochester, NY
Did it rain recently? your A/C evaporator drain is on the Passenger side kick panel as well the heater hoses, if thats coming out of the firewall, its got to be water from the cab, does it have any color to it?
R
Roman_78
Evansville
Ok no color. It did just rain. Let me snap some photos. Also my check engine light came on and this is what the computer said it was any ideas?
kurek
Northwest
That little nipple below the computer is your A/C evaporator condensation drain. When the air conditioner evaporator gets cold it sweats just like a cold can in your lawn chair and that water has to drip somewhere. If you were in Arizona you'd barely see anything but you're in the Midwest so you know how humidity works.
So unless it's shooting out of there like a garden hose somehow I wouldn't worry about the drip at all it's normal that's what that hole is for.
As for the cooling fan that's a separate issue, and yeah you want to address anything to do with cooling ASAP because an overheated engine means a dead truck and I don't know about you but when I was 21 a new engine wasn't in the cards financially for me. Heck I'm more than twice that and it's not something I'd be eager to buy.
One other bit of advice you can choose to pick up if you want it - keep your engine really clean. It's a good exercise, good habit to get into and when problems inevitably arise it makes troubleshooting and repair infinitely easier - plus it's an easy way to feel pride and earn respect when someone else sees that you're taking exceptionally good care of your equipment. If nothing else it just looks cool - sorry if that all sounds like **** an old man would say but that's what I am and it's advice some of the better old men gave me when I needed to hear it too.
Plenty of guides on the internet for how to clean an engine, here's what I have to offer: don't spray pressure directly into your radiator (the fins are delicate), directly into your alternator (the bearing lubricant can get washed out), your A/C compressor clutch (same reason) or directly into the cloth insulation liners because it will get degraded and begin sagging and falling apart. Just about everything else is fair game. Scrubbing bubbles (the stuff for bathrooms) aerosol is amazingly good at removing grease build-up without damaging rubber or paint. Liquid castile soap (like what you might use to shave with if you're a soap-and-blade man) is unbeatable for general soil and soot, and baby-butt mild so it won't damage any of the materials your vehicle's made of. That stuff plus some washcloths, plenty of water and a scouring pad or two will clean about anything under the hood and under your truck.
Good luck man I hope that cooling fan trouble code ends up easy for you to fix.
R
Roman_78
Evansville
I cleaned it early August and now I’m in college and just don’t have the time. Thank you for the advice.
Fryekenn
