very nice. Do you have links to the bulb you purchased or know the brand?I purchased 4 LED bulbs from Aliexpress, they're working pretty well and were plug and play in the fogs, and took a little finagling to fit in the lows. I did not better with the highs, I usually find I don't need the highs that often.
Here's a album with titles
Thanks.
This is what I bought. Right now there's a link there for the most recent posting, for a while they didn't have them again. I saw a lot of similar bulbs on ebay but for about 2X more, if you don't mind waiting a 2-4 weeks to get them these look to be the same.
Thanks.
Thanks, I just ordered them. For $44 I'll give it a try. The description says H8/H9/H11. I'm guessing they are all compatible? Did you ever select H11 in the checkout process?
Awesome! That's exactly what I did. Thanks for the reply! You prevented weeks of worrying about receiving the wrong bulb.When placing an order there's a way to drop the seller a note to say what bulb you need. I ordered two so I'm told one of each for the fogs and lows (forgot the numbers).
Had them in since Mid-March. Pretty good so far, I have noticed at idle every so often one of the lights flickering but it's hard to see/notice. Once I hit the gas it stops.Awesome! That's exactly what I did. Thanks for the reply! You prevented weeks of worrying about receiving the wrong bulb.
How long have you used these bulbs?
Interesting, that sounds like you might benefit from the Big 3 audio upgrade (possibly). I'll post up my findings after I get them. Thanks again!Had them in since Mid-March. Pretty good so far, I have noticed at idle every so often one of the lights flickering but it's hard to see/notice. Once I hit the gas it stops.
So I need to correct this statement. After further research and following the links posted here, LED headlights actually put off a lot of heat.You shouldn't have to worry about that with LEDs. They will run much cooler than halogens. If it's not too much to ask would you mind taking a picture in a place absent street lights, one with foglights on and one without?
Sent from my HTC One using Tapatalk
Here's my take on it. If you have a quad setup I would say go for LEDs in the low beams and leave halogens in the high beams. I say this because the kind of light that is put out by each is different. The led light is much "cleaner" and brighter then the factory bulbs and it's difficult to describe, but the light reflects back to you much better. It's almost as if the objects glow with their own light as opposed to the LEDs lighting them.So are the LED bulbs a decent upgrade to the stock quad low beam headlights? I understand HIDs are better, at least in the opinion of a majority of this forum's members. Obviously adding a lightbar or other auxillary lights will increase output also. Are you happy with the LED buld as a low beam replacement on its own and is it an improvement when compared to the stock quad low beam?
The 2015s have a whole new set of complications when it comes to lighting modifications. If you are interested in upgrading I would consult with JJRetroShop before purchasing anything. He'll be able to point you towards what works and has most of what's needed on hand.anyone try em on the 2015's?
