Plz help
Dodge newby
5.2 ltr
I'm new to dodge and newer to this forum
Please help
I bought a 99 ram 5.2 ltr 2wd automatic
It lost power on the freeway and started misfiring
Now it will crank over but won't start. It wants to tho
I replaced: crank/can sensors. Timing chain with gears
Plugs. Wires. Air filter
This fam thing still won't start
If it does it misfires so bad till it dies a second layer
Please help. I have no idea what else it could be
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
any codes from the check engine light?
D
Dodge newby
5.2 ltr
No codes. According to the expensive scanner
My brother put on it
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Have you checked to make sure all the plugs wires are on all the way? Checked to make sure your getting spark to the cylinders?
Also may check for a vacuum leak, may have bumped one off.
D
Dodge newby
5.2 ltr
All the wires are on all the way in te correct order
When I check for spark wwith an inline tester it's a low or dim light
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Which cylinder gives you the low/dim lights?
What plugs did you put in?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Did you replace the cap and rotor? You may have gotten a bad coil. But low spark is where I would start first. For best possible starting scenario use champion copper plugs. Replace cap and rotor. Double check the wires for the right ohm resistance. and double check the firing order. That's where I would start.
D
Dodge newby
5.2 ltr
The coils and wires ohm out to the correct number
And I've checked the wires in the correct order too many times to count
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Ok well that rules that out. Just trying to be thorough. What about the cap and rotor? They look good? No cracks smoke trails or anything?
D
Dodge newby
5.2 ltr
Cap n rotor look great
I'm going to see if maybe my exhaust is clogged
After work
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Checking the cat was going to be my next suggestion
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
If you don't have inspections you can just hollow it out
SmokedRam
Zephyrhills, Florida
Hahaha. I'm in California
They pretty much check my undies for stains when the smog it
LOL...that's funny right there...those California emission trucks, direct fit cat systems are $$$$ Magnaflow makes one, Part #M6645285 which runs about $500 or so...Walker makes a universal one, part# WK81512 that usually runs about $220
