Popping under floor board after level install
Jrock2394
5.2 V8
So today i finally got around to installing my 2.5" level kit from HBS with extended Rancho Shocks. Everything went good and love the look of it but now i have a popping sound under the floor board going over small bumps. It almost feels like a heart beat thump.
I triple checked every bolt and made sure it was all torqued to specs. And i just put a brand new trackbar on last month. Im trying to isolate where the popping is coming from. Its going to the shop Wednesday for an alignment and i was going to have them see if they can find the popping but if its something i can do and save money that would be better.
Has anyone had this problem?
ramittome
Gonzales, LA
I have the same sound with my drop. Sounds like its coming from the rear, but I can't find it.
Jrock2394
Jrock2394
5.2 V8
Just went out and re torqued them. My ride to work will be my test drive.
ramburger
and your testdrive will be infact flawless
Jrock2394
Jrock2394
5.2 V8
Just got to work still popping but not as much as before. And i did isolate it to the drivers side floorboard. I did notice the bushings on the new shocks are different than the ones i had on before maybe that has something to do with it?
mda8569
Vandalia Ohio
5.9 magnum
Just had a similar problem. No level kit but new shocks. Like Merc said, lower shock bolts have to be stupid tight. I also cranked more on the uppers,track bar, and the body mounts. I got some out of all of them, so not sure what did it, but it stopped.
Jrock2394
Jrock2394
5.2 V8
Thanks for the advice guys, just a heads up on this. Took it to get aligned yesterday and the popping has went away. No idea what it could have been.
Howells
Kitchener Ontario
5.9L
I had to put a washer in there to take up some of the slop then was good. Stick Ur hand through the spring if u can move the shock it's going to thump
