Positive camber?
smurfs_of_war
Swift Current, Saskatchewan
I noticed since day one my truck *looks* like it has some positive camber out front. Is this normal for a power wagon? Called a few places and kind a few different answers. 'Normal', 'somethings off', and 'power wagons have their own alignment specs so it's tough to say'.
The alternative is I have negative camber out back, but that likely means a bent axle so I am hoping it's up front [emoji1787]
SeppW
Northern VA
Hemi 6.4L
Worn ball joints could cause issues, but I wouldn't expect them to be worn n a new truck. I don't know about the 2020's. but I assume the camber is fixed, i.e. not adjustable. A long, long, time ago you could adjust camber by using shims on a straight axle. Only toe and caster are adjustable. Just for the hell of it, check your articulink cams are set the same on both sides. Good tech info here: https://www.thurenfabrication.com/tech/alignment-and-handling.html.
smurfs_of_war
smurfs_of_war
I checked those cams first thing as they gave me grief on my previous truck, but good suggestion :)
It may be an optical illusion. I guess when I get to the city next I may get them to check it.
olyelr
Kewadin MI
When you say positive camber I am thinking you are talking about the top of the tires sticking out slightly compared to the bottom. If so, I think this is normal. I have always noticed that with mine.
I used to always look at the front tires from the back, comparing them to the rear tires, on my 2000 half ton ram. When i saw them leaning in on the top, thats when I knew it was time for ball joints and wheel bearings again LOL.
smurfs_of_war
smurfs_of_war
Yes, that's exactly it. The tops stick out slightly compared to the bottom.
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
Ok cool. I can put that one to bed then. Given it tracks true and doesn't pull all over I was kind of thinking it must be, but wanted to ask those who know more :)
Your wear pattern on your tires would till you in 3-5 miles. But if you are running 65 psi you probably already wore out the center.
olyelr
Kewadin MI
I can vouch...they lean out at the top a bit.
