pre applied thread locker
Flryder
Bradenton, Fl
I am replacing the exhaust manifold gaskets and having the warped manifolds resurfaced. I got all new Mopar hardware and gaskets. The manifold bolts have a brownish pre-applied dry threadlocker on them. From my research I found that dry threadlocker has encapsulated hardener/activator that will be made active by being crushed open during the screwing and torquing of the bolt into the cylinder head. So, from what I found I should not need to do anything in addition to bolting up the manifold and torquing to 18ft/lb. Is this correct?
Thanks,
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Thanks,
Is your question whether you should use thread locker or new bolts?
If bolts are new just torque to spec.
Flryder
Flryder
Bradenton, Fl
I just want to make sure that I do not have to do anything else than what I described.
Tach_tech
5.7L HEMI
No, just tighten to spec.
