Tucdog
Just passed 30K and am going to have the filter changed. Any additive/injector cleaner I should run prior to or after getting it changed?
Thanks!
Thanks!
If your not towing an have lots of city stop & go driving some like to run an injection cleaner every 5K, some say its not necessary, my self run an injection cleaner every 5K being mine does not see regular heavy towingJust passed 30K and am going to have the filter changed. Any additive/injector cleaner I should run prior to or after getting it changed?
Thanks!
First time changing it? If so, post a picture...they're pretty nasty after 10-20k miles.Just passed 30K and am going to have the filter changed. Any additive/injector cleaner I should run prior to or after getting it changed?
Thanks!
I do the exact same processThere's a few videos and articles on the subject, but there is nothing wrong with running something either at every oil change or at every fueling.
I put this in when I refuel: https://www.amazon.com/Hot-Shots-Se...locphy=9030250&hvtargid=pla-570724904073&th=1
I'll put this in when I change the oil: https://www.autozone.com/fuel-and-engine-cleaners-additives/diesel-fluid-and-additives/p/hot-shot-s-secret-diesel-extreme-clean-and-boost-16oz/1350775_0_0?spps.s=2701&cmpid=LIA:US:EN:AD:NL:1000000ER:19488533498&gclsrc=aw.ds&gad_source=1&gbraid=0AAAAADkcoVsYvvJCFc_6vctSgU4xK_RaU&gclid=CjwKCAiAneK8BhAVEiwAoy2HYbWttOFthiWdb3BICsEEhe4Sd4UTkIvfM9ZnYlqz60ryGX-dNkb9wBoCYYIQAvD_BwE&new_store_set=true
You'll want to shorten the filter changes to at least every 20K miles, some guys change it every 10K. There only one fuel filter on the EcoD, unlike the Cummins with twoJust passed 30K and am going to have the filter changed.
