Question about 35s
jgruberman
EcoDiesel 3.0L
I have a stock height 2015 EcoDiesel Lonestar edition 4x4. What would I need to do to the height to get just enough clearance for 35s? I don't want to go crazy and I would LOVE to fit in the garage still, even if by half an inch :)
I saw a guy at the tire shop with a 3rd Gen and he had them and said all he needed was 1.5" lift in the front and he has VERY minor rubbing when the wheel is turned all the way.
Should I get a lift, spacers, or Bilstein 5100s to accomplish said goal?
2011 Ram 1500
Bilstein 5100s would be the best thing to do and I only rub on full turn which can be fixed with a spacer or an aftermarket rim with good offset
jgruberman
jgruberman
EcoDiesel 3.0L
I was going to use the stock rims for cost sake and I like them :) what width spacer? what do you have the Bilsteins set for? Max height? I assume you have the same truck?
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Go for the Bilstein 5100's. You can get them from jet.com for like $150 for the pair.
Adam
jgruberman
jgruberman
EcoDiesel 3.0L
Adam
Shoot, I can get them local for like $120 a pair. Do they need to be at a specific setting? And should I get a pair for the rear just for the sake of them all bring the same? How much will they raise the truck?
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
That's a good deal. I wouldn't get the rear shocks... The Bil's have 4 settings and maxed at 2.8 would raise the front up to around 2". There are a lot of topics in this forum that can probably answer a whole lot of your questions as everyone has been postin about them lately, including myself.
Adam
AustinB
Banned
San Diego, Left Coast
As cheap as you're getting them... Yea I'd snag up a set for the rear. Not really necessary, but I'd do it.
I paid right under $200 for my bils before all these deals kicked off. So for $40-$50 more (theoretically) it's worth it.
jgruberman
jgruberman
EcoDiesel 3.0L
So the Bilsteins at max setting will give me clearance for 35s with the possibility of just needing a spacer to clear when the wheel is turned all the way?
kg93
AZ
yes max bils and a .25" spacer on stock wheels will give you enough clearance.
R.L.K.
Bristol , Tn.
I've heard several people with the bilsteins and a 1/4" or 10 mm spacer running 35s with no rub . It's a bit of a stuffed wheel well look but it seems to work .
If bills maxed out ( top ring @ +2.8" ) makes your front too high just install a .75"-1.0" coil spacer in the back to achieve level
xrsman
Ontario
3.0 Ecodiesel
Why buy an ecodiesel if you're going to ruin the mileage with 35's?
Bilsteins are what you should use for the level, and BORA wheel adaptors are what you should use to space the wheels out. I have 1.5" and they look great.
Be prepared to lose 5 mpg instantly with the 35's though.
Sent from my SM-G920W8 using Tapatalk
danam
Dublin, Ohio
2010 Dodge Ram 4WD SLT Quad Cab
4.7l
Wow. Will I lose 5 miles per gallon if I went with the same setup driving my 4.7 liter
xrsman
Ontario
3.0 Ecodiesel
Yes. 4-5 mpg loss as soon as 35's are put on. They take a lot of power to turn!
Rzrman328
The treeline
Yep...that's the crappy part to running big tires.
chipmaker
AZ
I have Bils @ 2.1" and 35's on 20" stockers. I certainly didnt lose 5 MPG. Maybe 3 at the most.
jgruberman
jgruberman
EcoDiesel 3.0L
Just so I understand, the Bilsteins actually raise the truck by 2.8" at max level? So putting them all the way around is somewhat equivalent to a 2.8" suspension lift?
fordtech90
Jonesboro, La 71251
Also where are you guys getting these 5100 adjustables for $120-$150 a pair? Everywhere I call they are $130 EACH!!!
jgruberman
jgruberman
EcoDiesel 3.0L
What about 33s? What kind of MPG loss comes with those? Anyone running?
joshhhh
