rotwiler
Right now Infinity kappa 1200w(500rms) subs are $99 on Amazon prime, like $100 less right now than normal price. I think infinity is coming out with new model so discounting these in half. I like good sound quality and lows, so thought these would sound good for both and excellent price, in future can wire to 1 ohm if I buy new amp(selectable impedance on the subs) . They need .9 cf airspace sealed by manufacturer specs. I should have 1cf now, so should be perfect airspace wise. My homeade by member here fiberglass box is not divided, is open for both 12s. Does dividing box help sound quality or does it sound pretty much the same? I never used a box in past with 2 subs, only divided. I read people say if you blow a sub, you can't tell like a box with seperate airspace. If I fill in box to give subs own airspace it won't be perfect, just a guess at size but both should be at or close to .9cf. My Amp is 1,000 watts rms @ 2 ohm, so will be right at the limit, I prefer a 100 or so over specs, but should be good.
