RAM 1500 towing; lackluster?
leroys73
Dallas Area
4300 lbs, my 2009 Chrysler mini van is rated at 5000, not that I would ever try that.
Black1500Ram
Scottsdale, AZ
Move to the Hemi and even with the 3.21 gears you’ll be much happier.
If you get a hemi make sure to use the oil and filter recommendations on this forum not what FCA calls for.
Essentially royal purple 20-820 or 20-500 / fram xg2 or xg10575 NOT the xg10060. Oil filter thread.
And there's the Synthetic Oil thread as well.
Top picks are redline 5w30, m1 fs 0w40 and others.
If I weren’t going through lifter issues right now, I would absolutely love my 5.7 1500.
Tony1945
Needles
Ram 2019
V8
Hello all, first post here, and possible prospective RAM owner.
I'm currently in the market for a newer truck. My 4.0L 4dr Tacoma has been a reliable machine that's never let me down. My son is really needing a truck for work (self employed carpenter) so I figured I'd help him out for letting him have the Taco for a steal (half of book value) and I'd "upgrade" to something newer.
So, it came as a surprise to me that the 1500 Classic has only just a "bit" more towing capacity than the Taco!
What I tow on the regular:
6' x 10' utility trailer loaded with raw material for my machine shop or metal chips every 3-4 months, never above 2k pounds, or the same utility trailer except loaded with a Polaris Ranger (700 pounds or so) and a couple dirt bikes in the bed, along with gear and kiddos.
I really did fall in love with this RAM, am I setting myself up for disappointment? Would it be possible to make it more "tow worthy"?
I need the bed capacity for my work (machine shop, part deliveries), the quad cab to haul kids around when camping at off roading, and the fuel efficiency for light errands. Zero plans on a camper, boat, or horses (much to my daughters dismay).
Ive had both the ram 5’7 is the trick or 3.0 eco ride alone is a sale
Steve-wells
4.7 v8
My 2008 Ram with 4.7 has not enough power to pull my 20' enclosed trailer weighing about 3000#. Using tow haul, I can't maintain freeway speed (75) without the engine at 4000 + ram. Wish it was a larger engine and a tow package. Only has 81000 miles. K&N air intake not much help. Tuneup in the near future with all 16 spark plugs replaced. It came with my new wife.
06 Dodge
Forest Grove, Oregon
6.7L CTD
Why would you want to run 75 MPH while pulling a 20 ft trailer? My FIL pulled a 4K 18 ft trailer with his 4.7 from AZ to CA, OR & then to IA an back to AZ without any complaints, but then he was not trying to run 75 when towing... Also that K&N if you bought it was a waste of good $$$$....
star_deceiver
Airdrie, Alberta
3.6 Pentastar
You are towing a giant air brake sail. Weight has little bearing in the flats.
Here's some rpm and temps of me towing my TT up an 8% grade.
Also, if the rpm drops below 4500 I won't be able to hold speed and it'll drop down to 2nd, where 5500 in 2nd is about 45mph.
Orca
