Ram 1500 Wheel Bearing?
seturner
Hi,
I have had a noise ongoing for a while with my 2wd 2014 Ram. There is a high pitched whine from the front. I jacked up the front of my truck today and spun each front wheel. The right front made the noise in the attached video. The noise is loudest at 45mph and I can feel a vibration in steering wheel when slowing to a stop. Thanks
[yt]tglk6eDz4Z8[/yt]
huntergreen
Marine Corps Navy Badge
could be, would be odd for a wheel bearing to go out on such a young truck unless you really pile on the mileage.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Wheel bearing went out/did the same thing on my wife's 2015 Dart at 6k miles
M² Mods - From my non Flammable S7!
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
I've had a wheel bearing go out on a brand new car at 600 miles, you never know.
The best way to check is to lift the wheel off the ground, grab the wheel at the top and bottom and see if there is any bilateral movement when you shake it.
VB712
Maxi_built
Va Beach
Make sure there aren't any rocks or anything in between the rotor and dust shield.
