Ram rebel tailgate
USMC_Ram909
Can the big "RAM" logo be put on a '12 CC tailgate? I haven't seen what the look like on the backside, 3m or studs. Or if my regular ram emblem in the back is 3m or studs.
CC12RamLove
Escondido CA
If im not mistaken. Your ram head is held on with 3m and studs for positioning same as the large "RAM" i would think your best bet would swap the hole tailgate.
Sent from my SM-N920P using Tapatalk
PrdCdn
TEAM RAMROD
Right Here
H/O 3.0L Hurricane
the rear Ram is actually inset into the tailgate. Meaning once the emblem is removed, there is a "dent" in the shape of the emblem. Plus 2 holes for the emblem sits in for alignment.
so hopefully the A in RAM will cover that ... a guy would have to make that work.
Personally, I would love the RAM on the Rebel to be stamped in the metal AND not a decal. I think they cheaped out - go back to the basics - bring back the stamped metal.
Solid State
2011 Bighorn
I'm pretty sure this has been brought up before. I think the consensus was that the' A' would not cover up the indentation from the ram head. Maybe swap entire tailgate out?
Farmer Fran
Earth
2025 Limited Longhorn
SST H.O.
Holy Crap... $34.xx per letter.
OnSale
5th Gen Crew
Philadelphia, Pa
You will need a new tailgate as there are holes to mount the RAM letters
Not true. The new letters come with both 3m tape and small little "posts" on the back of them so all you need to do is cut off the small posts with a razor blade or a pair of snips and then you will be left with only 3m tape on the back of the letters.
Of course you will have a big indent/mark where your original Rams head logo use to sit so getting a new Tailgate with out the Rams head might be a good idea, but it's definitely not required.
Sent from hell via TapATalk
averageguy
Belleville Mi
hemi
I saw one the other day that someone had put the huge RAM under the rams head emblem.
