mcripps1
Hello. I have a 2018 1500 Laramie that I have owned just over a year. For the third time in 6 months the alarm triggers and it can't be canceled with the key fobs. I have replaced both key fobs batteries. While the alarm is blaring, I can get in the truck and start it and drive away, all while the horn is blasting. The first 2 times this happened it had rained previously, and I had used the fob to unlock the doors. As soon as I opened the doors, the alarm went off. This last time it started up on its own in the driveway. The only way to stop the horn is pulling it's fuse. After a bit, the alarm must reset, because it stops blaring the horn. Im at a loss to figure out where to start looking. I can't afford a dealer diagnosis and repair. Does anyone have any ideas? TYIA
