I would agree with Wild One ...and not only check your battery but cable connections and grounds too. Check pos cable connection at the fuse panel. When my battery went out I was getting a lot of cluster warnings that I don't normally see on vehicles. But if your vehicle still starts, then that alone is probably a good enough load test. But still have it checked. While they are checking it, have them scan for OBD codes too. Write down what comes up.
Here are some other ideas:
1) Main fuse link
2) Check wiring below TIPM: There are a lot of connectors and many wires below the TIPM. you might want to lift it and look under in case a connector somehow came loose or a rodent chewed a wire.
3) Fuse connection board making good contact? The fuse and TIPM have are a sandwich of boards and contact pins for fuses, etc. have been reports of the lower fuse board sliding down and not making good connection. If all else comes up empty, it's worth looking at.
4) Fuel pump relay? Not sure how likely this is, and I don't recall what the 'while driving' symptoms of a bad fuel pump relay are. But if it develops into larger no-start issues it's something to keep in the back of yer mind. Second link below gives you an idea of how to get to the fuse pins and fuel pump relay. There's also a $12 fuel pump bypass wire you can buy off ebay.
But first check all your cables/grounds/battery. That's the most likely. You need to load-test the battery. If your vehicle does start, then that's probably not the battery. But definitely could be the connections/cables.
This video shows how to raise the TIPM/fuse assembly to inspect the connectors and wires beneath it.
Email:
[email protected] Call: 818-793-7888 or 818-798-5558Visit our website to shop for tipms and more info:http://tipmrebuilders.comMak shows you how to...
www.youtube.com
This video shows how the lower circuit boards and fuse panel go together. You should be able to tell from the top if the fuses and fuse pins are making contact.
Edit: Relay is an ex1-2u1s available with 2day shipping under $20 at vertical VisionsMany Chrysler vehicles made between 2008 and 2014 were made with totally...
www.youtube.com
