Rattle that's driving me nuts!!
Jeff Krawczyk
Massachusetts
Well I have been under the truck a few times to try and find this noise/rattle and all seems tight...it only happens at a certain rpm which leads me to believe it's something on the exhaust, it is getting a bit more frequent, it comes from the back....has anyone had this issue or have any ideas....thanks
Brandon-w
Yukon
2015 Ram 1500
Muffler baffles broke loose?
Jrod
USAF 1997-2008
Virginia
2025 Laramie
SST SO
Tighten all of your side step bolts.
indept
South Jersey
Maybe muffler bearings.( Just saw that Brandon -w posted the same comment)..
Seriously, have you checked everything with the truck jacked up to relieve any stress on the components?
Brandon-w
Yukon
2015 Ram 1500
Sometimes the Goofy pinch welds in the muffler break Loose and rattle not a joke lol. Muffler bearings is funny but seriously you need a halogen fluid top up. Try smacking the muffler with a rubber mallet or. Have someone load the truck up to the rpm.it does it.
Jalynsdad
Oklahoma
5.7 L Hemi
I've had a similar issue with my 2015. Mine does it when I start the truck until the RPM's level out and I have noticed it happens sometimes when I am slowing down at about 15MPH (Not sure where the RPM's were) but when I step on the gas the rattle goes away. I have gotten under the rear end of my truck to try and find the noise but a friend suggested that I follow my exhaust from the manifold all the way to the back to check for anything that is loose. I haven't had a chance to do this yet, but hopefully I will soon! If I find anything I'll update you!
RamCares
n/a
n/a
Hello Jeff and Jalynsdad,
We certainly understand why this would be concerning! If you're not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your dealer, please let us know via private message. We would be more than happy to provide you with an additional layer of assistance for that process.
Laura
RamCares
