Rear AAM 11.5 8x200 to 8x6.5
nik632
Minneapolis, MN
6.4l HEMI
I've got a 2018 Ram 3500 DRW chassis and cab that I've put single wheels on for an overland camper. I'm looking to order a 2020 Ram 3500 DRW chassis and cab with better options.
I would like to move the wheels and tires to the new truck. My problem is the new rear axle bolt pattern (8x200). Both are AAM 11.5 with 4.44 gears. Is it possible to replace the 2020 axle shafts and hub assemblies with 2018 axle shafts and hub assemblies to get the 8x6.5 bolt pattern?
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
Hi,
Can you send me your 2018 VIN so that I can identify the axle/hub part numbers and then I will check compatibility with the 2020's
Thanks,
Benny
AllMoparParts.com
- Benny
All
All
After looking into this I am not sure how much help I can provide. The parts on your truck are only used up to 2018. In researching the 2020's I do see that there is a shared sales code DRX which designates 11.5" DRW but I am not sure if this means all 11.5 setups share the same wheel bolt pattern. I also do see that a 12" setup is available as well. Do you have the proposed build sheet of the new truck?
N
nik632
Minneapolis, MN
6.4l HEMI
Don't worry about it. I think it might work, but I'm going to pursue a different solution. I appreciate the research.
AllMoparParts.com
- Benny
All
All
OK, best of luck and i hope all goes well
Happy New Year!
TMFMK
