Rear diff cover bolt torque
EdGs
FL
2015 ram 1500 QC 2wd, anyone have the torque specs for the rear diff cover bolts?
Thanks.
EdGs
EdGs
FL
Ok, thanks.
107k, going to open mine up and see how it looks in there.
Daw14
South Florida
I just changed my oil and cover today, although the cover is a B&M , the torque was specified at 15 ft lbs.
EdGs
EdGs
FL
Pulled the cover on my differential today. Oil was semi-dark, but free of debris. Took about 2.6 qts. to fill. Life is good.
Coolant drain and fill(s) tomorrow.
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
must be the season i changed my rear differential fluid today
ram1500rsm
Trabuco Canyon, CA
About to do mine since I’m at 95k miles so I’ll pop the cover out for it’s first time. I’ve been doing drain and fills.
I thought the tq for the bolts were 30ft/lbs?
EdGs
EdGs
FL
Torqued mine to 15 ft-lbs., no leaks.
I was kind of shocked at the amount of rtv that was used by the whoever did it first - there was damn near a 1/4 inch bead squished over the inside edge of the diff most of the way around.
It lasted for the 80k that I've had the truck, glad for that.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Nothing like a clean rearend...
ram1500rsm
Trabuco Canyon, CA
Mine also had a thick bed of red atv it was kind of crazy. I ended up giving my bolts 240 in/lbs, which is 20 ft/lbs.
Here is torque sequence from my lubelocker gasket.
50777701376_19e905e04a_k.jpg2020-12-29_07-00-49 by RAM RSM, on Flickr
