Black1500Ram
- Joined
- Jul 18, 2021
- Posts
- 621
- Reaction score
- 1,047
- Location
- Scottsdale, AZ
- Ram Year
- 2015
- Engine
- 5.7 Hemi
Delete
Does it say anything about carrier bearing preload? I might give them a call.Just go buy the specs in the Yukon book. and Initial torque of 210ftlbs is just the minimum you need then you keep torquing down until you get your pinion pre-load.
thats why i said to have 2 crush sleeve as youll probbaly f it up on your first try. Heck I f it up once in a while to this day. But I always send it with my Milwaukee 1/2 impact
Even with all my fancy tools, i use this tool when checking my pre-laod, https://www.amazon.ca/Neiko-03727A-4-Inch-Torque-Wrench/dp/B01FMXEWQC/ref=sr_1_4?crid=2CS6ZZH8XU24A&dib=eyJ2IjoiMSJ9.IX6ICIeGY4HuCNL7FFF6KJ2JT9apxFZDr8jvKg0wptng-3BQdzizj2v9dIrS88nemFArZKuPUlZfOkKqYzGdpnJXbHd5a47RQK7mUjpRtFawHO_iDYm91H1OErpQEaR5eyul6cHDzcLX8MaKoAqQdWU-J81eS8nG90W7jtYyHppT9Gf-NYWbvNZMNVcAWg0FMwlyJaR9NsCA7jpFBXmgR69idYeKk40BirOJlfbmLfKZ5zZ5A8goihjH6XY9Gr-rQYjV9TqR_NNIZwBukEwkzbg9ljGUATIiWJyfZzkru88.3y7a-IPKw02HG1evGssAGGt4HIQh-5tKhtUOVEWel3k&dib_tag=se&keywords=1/4-Inch-Drive+Beam+Torque+Wrench&qid=1725885172&s=hi&sprefix=1/4-inch-drive+beam+torque+wrench,tools,114&sr=1-4
This guy has the best video https://www.youtube.com/watch?v=JWbsYrCvy-0&list=PLZiPM9pGwXmCBdKSHUag0bGqxW446QGik
Inquired with Yukon their response was to torque the side adjusters to 100-150ft lbs.Does it say anything about carrier bearing preload? I might give them a call.
I highly recommend this advice to have 2 crush sleeves.Just go buy the specs in the Yukon book. and Initial torque of 210ftlbs is just the minimum you need then you keep torquing down until you get your pinion pre-load.
Yeah I didn’t take it a part again I was surprised how quick it took up on the turning foce, but I guess it makes sense.A couple over won't hurt,, I always set mine on the tight side. The GM 7.5 I did a couple days ago was over by 2" lbs. I sure didn't take it apart the gear pattern was way to perfect to touch it. And my backlash was spot on 6
