Rear end Sag
Deed
U.S. Navy....so Pretty much anywhere, at any given
Cummins Blue Tech 6.7
So, Taking a Que from an Idea that was Presented on the forums and Wanted to Add a 50gal Aux tank:
FTC50 Auxiliary Fuel Tank
Roughly a normal 55gal Drum of Fuel weighs about 435 LBS, I currently have a 6" Rough Country Lift on my Truck on 35's soon to upgrade to 38's. I haul my bikes around with little to no Sag.
My Question is, Should worry about Sagging with a full Load, with the added weight. and If so, what should I add to Correct the Sag without Raising the Back end of my Truck, I would like to keep a leveled Stance.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I would try to find an airbag helper that would work with I'm guessing blogs in the rear
This option would allow you to adjust depending on how much fuel and/or bikes you have
I would see how your trucks sits first though I didn't notice you had an HD
Stangshcky12
Oshkosh, WI
5.9 Cummins
There are a few kits that are just a bolt in although having a lift might make it tough
Im working on some homework now but Ill try to look around for something later
Its actauly something I have though about before since I plan on the same RC kit and I tow 10-12k lbs reguraly with the truck
Deed
Deed
Stangshcky12
Oshkosh, WI
5.9 Cummins
I'm thinking the timbrens may be your better bet as the replace the bumps stops and go between the leaf and frame unlike the Ride rite bags which go between the axle and frame (assuming your rear is lifted with blocks)
Deed
Deed
It seems a little cut and dry, and pretty simple to do...but that's not my luck normally rolls. I guess I'll just order it and see what happens, I guess worse case scenario I'll get about an inch of raise with no load... so that wont be too bad. or am I looking at it wrong?
Stangshcky12
Oshkosh, WI
5.9 Cummins
As far as I know the timbren replaces the bumpstop and acts like a progressive spring, with more weight applied it will become stiffer(as its compressed)
Unloaded your truck should ride like stock. 450lb might not be enough to compress them down to the axle but that would also mean you aren't sagging much!
I found these pictures and it looks like you might have to modify them to work with the lift as well
You would probably have to add a spacer as thick as your lift block
Amazon seems to have the best price on them although I didn't look very hard cause I'm on my phone and can't sort by prices
Stangshcky12
Oshkosh, WI
5.9 Cummins
I also noticed people talking about an optional spacer to use on truck that were basically always loaded
Maybe you'll luck out and thatll be enough for your setup
Jtucker21990
