Rear light bulbs
Hot94Z28
When I was leaving my local Wally World I had my left rear tail light pop up as bad. So I went back in and found only the LED replacements so I bought them. Then it showed both were bad, I went another Wally World and bought just the regular replacement bulbs and still shows both as bad.
Now both sides are working, LED, regular bulbs, and still shows both sides bad when it just showed the left side as bad. It’s working just pops up they are bad and was wondering what a fix is? Any help is welcomed.
OC455
Central NY
If you put regular incandescent 3157 bulbs in the truck, it should be fine and the EVIC display should clear itself. If you use LEDs then you either need CANBUS compatible LEDs to "fool" the system into thinking there are regular incandescent bulbs.
If you have AlfaOBD app and a DatalinkMX you can change the Body Control Module setting for the lights to LED and it should eliminate the problem.
As far as using the regular incandescent bulbs, it may have to go through a few starting and shut down cycles to clear it...
Hot94Z28
Hot94Z28
Guess I’m putting the regular bulbs back in, I figured if it’s going to fault out might as well have LED’s.
McBroom
Denison Tx
Hemi 6.4L
You could use the resistors if ya really want to use the leds
I love my truck!
Blue Mule 18 Ram 4x4 C/C
Tradesman Power Wagon
Hot94Z28
Hot94Z28
I love my truck!
I got LEDs because that’s all they had. I hope it stops in a day or so.
RoadRamblerNJ
Mountain City, TN
392 Hemi
LED's are definately brighter by a large margin. They cycle on/off quicker too.
This might not seem important but, as a biker of 40+ yrs, three quick taps on the brake warns folks behind you to decrease speed and be prepared to stop.
With stock bulbs, I found my 3 quick taps was just one long brakelight. The bulbs wouldn't go off & come back on quick enough between taps to ever appear to be off.
LED's are fast. Now, without changing my input speed, I have three very distinct brake lights in a row.
Now, if I could figure out a way to tap the top of my helmet (cab) to warn oncoming trucks there's a cop up ahead of them! [emoji41]
Midnight Storm
One Badass Ram
Victoria, B.C Canada
I switched all my lights to Canbus compatible led’s off eBay or amazon. Never got an error code. Again I recommend YouTube boosted motorsports. He did all led’s and put links on what worked and what didn’t.
Hot94Z28
Hot94Z28
Bumping this cause I got AlfaOBD and tried to switch in my led bulbs, no dice. So I turned it off but after some time with the regular bulbs it still says bulbs are out but not all the time.
Is there a setting I need to turn back on? Any help would be appreciated.
