are you sure its not the seal around the third light on the roof it has been a problem leaking just try taking it off and putting some silicone on it and see if that does not fix the problem mind did the same thing and that is what it was[/QUOTE
Not to deter future posts from other members but it is not the third brake light. When the issue first occurred that was my first thought so I used a mister and sprayed the light and it didn't leak so for good measure I siliconed it anyway. After that I looked to the window which is where the leak is. If I spray water on the bottom section of the window it runs along the bottom seal into the track then down the jute. I've already siliconed the bottom seal corners once before and used pb blaster to moisten the seal but this was only a temporary fix. I am wondering if someone makes seals for these windows to try and replace them seeing as the silicone only lasts about six months.
