Reasonable plug/play door speakers for 2018?
caulk04
I'm not terribly disappointed with the audio in my truck (non-Alpine 8.4") but it's a little behind what my 08 Jeep had. I will NOT go whole hog with an amp, subs and so on but I'm game for a door speaker upgrade if there's something out there that's at least noticeable.
I looked through Crutchfield a bit and it seems to suggest 6x9, 6 1/2 and 5 1/4" speakers. What should go in the doors? I'm willing to entertain speakers nearing $100 a pair, no separate tweeters etc. Plug. And. Play.
PCA4208
Albuquerque, New Mexico
Dr. Righteous
Jamestown TN
What you will find is the 6x9 speaker opening in the doors is not the usual spec for aftermarket 6x9s.
I went with a set of Rockford Fosgates 6x9s that were about $119 a pair if I recall and they "mostly" fit.
I put some foam tape around the edges of the speaker for a good seal.
BTW the Rockfords have been excellent. I'm upgrading to 2 10s and a 1KW mono amp. The Rockfords are staying.
SitKneelBend
St. Louis
3.6 Pentastar
Get the Kicker Ram upgrade speakers. They are completely plug and play.
caulk04
caulk04
Thanks guys!
Administrator
^^^ I'll second this, no spacers or wiring adapters.
fronts - 77KICK28ab
rears - 77KICK41
maxiderm
Bakersfield, CA
Pentastar 3.6
Based on reviews and a lot of research as to what fits, etc. I've decided to buy Kenwood eXcelon series speakers for the dash and front and back doors, and a Kenwood eXcelon 5 channel amp. The 5th channel has a high power output for a sub, which I will probably add later at some point.
William Hastings
Aston, PA
I put kicker 6.5s in all doors, 3.5s in the dash. I think the cs series. Sound great, but absolutely no bass whatsoever. Just installed the pioneer 6x9s that wallacemf recommended above in a buddys 2500. They sound amazing for 40 or $50 a pair.
If your not going to install an amp, the pioneers are great bang for the buck. Just my opinion. Depends on your budget
jib88fer
Hiding in the Hills, TN
^^^^^ +1
6.5's = No bass. 4 pioneer 6x9s and new 3.5" dash spkrs is sweeeet. Less than $200 for all 6 i think. I have a sub box w/ two 10's and 600w amp i may not install now from my traded in 3rd gen ..
FlyTJ
Chicago
Curious about some of these recommended speakers.. they are all 4 ohm. Anyone experience lower audio after the install? Is it really insignificant compared to factory 6x9s?
The feeling i am getting from the reviews here are that it doesn't matter and the new stuff just sounds a ton better...
TJ
Gregdad
Fort St. John BC, Canada
I put these in my ‘19 Classic crew cab. The 4 ways in the back and 3 ways in the front doors. No spacers needed and sound more clear. A few days later I installed the Kickers in my dash and WOW, those little suckers really bring out the clarity. Had to fade to the back 1 or 2 notches.
I have a non Alpine 8.4 unit and no amp(yet), altogether it was about $250 Canadian
