Brand new truck so this may be by design, figured I'd ask. On every vehicle I've ever owned, if your recirc llight on the climate control was out that meant the fresh outside air would come through the vents even if the fan was not on, it would just be slow and dependent on how fast you were driving. Kinda of like the old "vent" setting.
On my new 14, there is absolutely no air flow through the vents in any position unless I have the fan on even with the recirc light off.
I used to leave my temp knob in the coolest setting(one notch up from max ac) and there would be a breeze through the vents while driving which is usually enough for me to keep cool, and in the winter just turn the temp knob up to warm and keep comfortable, never really used the fan much.
On this truck I have to use the fan to get any movement of air inside.
Normal or is something messed up?
