BulaienS
- Dec 12, 2020
- 17
- 3
- Location
- Genesee Depot, WI
- 2020
- HEMI 5.7 V8, 3.92 Rear Axle Ratio
I’d like to know why the front defroster on my 2020 RAM 1500 does not automatically turn on when the factory-installed remote start is used and the temperature is 40 F or below. The rear defrost turns on but not the front. I’ve not seen my rear window frost up but always see my front window doing so. In the winter (I live in Wisconsin) or the fall when the expected temp is below 40F I have to select the front defroster before turning off the engine. 9 times out of 10, I forget to do so then I have to restart the truck again just to turn on the front defroster before turning the truck off again so that the front defroster will be on when I use the remote start. I would think there can be a Uconnect software/hardware update for us to select either to turn on or off the front defroster automatically. The dealer called Chrysler with no help in this regard. They only say the temp is dependent on the interior temp, but the interior has been well below 40F when I’ve used the remote start so apparently, that is not an answer to what I’m concerned with.
