Removing bugs
glass3222
Central PA
What do you guys use to remove bugs off the front of your truck?
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
Unless you put in guttah grill, Are you tailking grill or radiator? I use bug tar remover on the stubborn ones but really I just wash it good and voila!. I use a hose on the radiator btw.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
There are quite a few things that work well on bugs. Of course, Fukken Wax!
But, for simplicity (and cost) - dryer sheets, bug/tar remover etc - all good items to remove bugs from your ride.
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Whats the skinny on price btw. PM or broad cast here?
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Thanks very helpful!!! Wax on! danielson.
glass3222
glass3222
Central PA
I was talking grill and hood from those bugs that get splatted going 75 on the highway that are a real pain in the a$$ to scrub off.
glass3222
glass3222
Central PA
Dryer sheets, huh, I might have to try that. As well as wd40. Never thought of or heard of using them.
Laramie1997
Springfield, Missouri
1997 Ram/2013 Charger R/T Super Trak Pak
5.2 (318ci)/5.7 (345)
Turtle Wax Bug off!
Spray on heavily and let set for about ten minutes. Then pressure wash off. What's left I remove with windex and a micro fiber towel.
matt99
Shreveport, LA
yea I usually use windex, spray it on and let it sit for a bit, and wd40 works great too
the first time I painted my grille with spray bombs I had to sand the whole thing down to the original surface because bugs were embedded in the paint
Laramie1997
I don't do WD40 just for the simple fact that it usually takes the wax finish off and I don't like that.
nim81
Fredericktown, MO
5.7L
my local carwash has a bug remover setting on their sprayers, it literally melts the bugs off, no scrubbing required. bugs can get really really bad out here in MO.
Deviate
St. Augustine, FL
2005 4x2
WD40 is awesome. Never used it for cleaning off bugs, but it's great for getting old stickers off.
Never tried the dryer sheets before, I am going to have to use them next time.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
damn me for mentioning dryer sheets. Fukken Wax does a better job! :D:D
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Simple easy plug.
Fukken Wax
I'm gonna have to cough up some cash and try this wax you speak of. But for me I just use a lot of elbow grease. I don't want too many chemicals on my paint. My paint is messed up enough as it is.
glass3222
glass3222
Central PA
Well, I got most of the bugs off, but I did also buy some FUKKEN wax
