Replace Hub / Bearing Unit
gbryant
Kansas
HEMI 5.7
Hello all...
I am looking into replacing my front right hub & bearing unit. I've noticed that the OEM is made in Korea. Also, MOOG makes a replacement, Timken, etc.
I would normally just go with OEM, but they seem to have reliability issues.
Is one of the aftermarket choices better?
Thanks.
G
gbryant
Kansas
HEMI 5.7
I ended up going with Timken hubs. Installing these solved my tire bounce problem.... but I still have a vibration that starts at 72mph and continues through 81mph.
I turned the driveshaft 180 *.... didn't help.
I guess next I'll replace upper lower ball joints???
Anyone have any input , help would be appreciated.
G
gbryant
Kansas
HEMI 5.7
yes.
I'm taking it in for alignment check after installing hubs... so I'll have them rotate and balance again.
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
How many miles on the tires? How much tread left? I try to get as many miles as possible out of tires but sometimes they wear funny and can't be balanced, only option is to replace.
G
gbryant
Kansas
HEMI 5.7
Quite a bit of tread left.... but if I have a bad tire , I'll replace it because the vibration annoys me.
loveracing1988
Clarkston, MI
Ball joints wouldn't cause a vibration. I would say it is the tires. They may need to be road force balanced if they haven't been.
