Replacement Battery Terminal Connectors for Add-ons
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
My positive battery cable terminal seems OK, but my negative is all rusted up, and jammed full of ground wires. I am thinking of simply replacing both +/- while I am at it.
Anyone have any brand recommendations?
JB1
Houston, Texas
I try to ground my lights to the frame with self tapping screws, a lot less wires everywhere and has been working great. You can also install a ground bus bar and only need one wire jumpered from battery to bus bar.
S0CAL
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
I may do the ground bus bar, that is a good idea. Curious what folks are running for the + side.
JB1
Houston, Texas
In my case, the power distribution box with the relays and fuses solved that issue for me, only required a single 8 ga cable from the battery to the box
