Rev limiter help
SILVER_BULLET
I installed my trinity on my truck this week and it's awesome but I keep hitting the rev limiter going from 1st to 2nd I turned the rev limiter all the way up I think it let's you raise it 600 more rpm from stock and at first I set the shift point to 6000 well that hit the limiter so I dropped it down to 5900 and still did it I'm down to 5700 and it still hits so tomorrow I'll probably set it to 5600 and see if that'll help but I wanted to see if anyone could give any advise as to why it's doing it or what I could try to fix it or if anyone has run into this with a 4th gen ram with a trinity
Musclemckeester
Houston, TX
n/a
n/a
I think mine is set at 5700. I played around with it even had it maxed at 6200 at one time but the truck had this terribly bad shift into 2nd so I kept taking it down til it felt right. I was on 5800 my last tune - I think Sean has mine set at 5700 now.
Sean will set all that for you though.
SILVER_BULLET
SILVER_BULLET
I guess ill just have to take it easy and wait till i can get him to tune it
tkyle486
how do you see what your limits are set at?
joshhhh
