Revs holding on too long after coming off throttle
baldnut
UK
Hi guys, I hope I have posted this in the correct forum (first post here).
I have a 2019 Bighorn and wanted to know if there is a way to remove the delay on the revs. Basically, after you push the throttle and come off the engine takes a second or two to release the revs, it tends to hold the revs (sometimes it doesnt) Is there a way to improve this?
Was thinking about the Trinity Diablo kit would this work, or is there another method available?
Darevrin43
Mine does this too, if I hit the throttle it sometimes takes the RPM's 5 to 10 seconds before it drops down but still takes a few more to settle back down completely. Very delayed with this truck on how the throttle drops in RPM's after a brief throttle increase.
13ram1500crew
Ontario
HEMI
Mine also does this, mostly coming onto the highway or any other higher speeds.
baldnut
baldnut
UK
Yeah I mean say you are sat and you want to rev the engine you can sometimes rev it a couple of times in quick succession but then other times it will hold the revs high even though you have come off the throttle. Was looking to see if anyone knew of a way to overide this?
RAMan92
Virginia Beach, VA
Pentastar 3.6L
Mine does the same thing, I believe it's how the 8 speed was designed, it keeps you in a higher RPM just in case you need to hit the gas again.
