Rim Question
4x4Wannabe
I am currently looking for new rims but i am wanting to run a 35x12.50. what rims would y'all say would look good for a decent price and stick out wider than stock ones. i looking for either 17's or 20's. pics would be nice to
ramhunter9
P-Star Jeep Wrangler
For a 12.50 you will want a 10 wide rim at least.
Look in my vendor room I have a sale on rims. Hit me up with what ya like and I will price ya.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
17 tires are cheaper than 20's and prolly ride nicer.
TheMaddog
DFW
I'll answer that one. It depends on your suspension, amount of air in the tires, and how big the tires are. You can have the nicest wheel and tire set up, but of you have a **** suspension, then you're gonna feel every imperfection on the road. My truck rides good, I just want something different.
I have 17's
4x4Wannabe
I have the stock suspension but about to put a leveling kit. I kinda leaning toward the MB Wheels TKO but i don't know if they would stick out like i would like
Wheel Details - Discount Tire
daggertats
arden nc
2011 ram reg cab 4x4
i was lookin at these on day and noticed they have 2 different ones. a positive offset and a negative one. a negative will push the wheel out of the wheel well however i cant tell you how much. might wanna call discount tire. anytime i had questions i talked to them and usually got the answer i needed . just noticed your truck is an 07 so the negative offset might not be available for your yr.
quietpeen
2021 TRX
Hellcat
the offset and width of the wheel will determine how much they stick out.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
here are mine. 35/12.50/17 10inch wide with a 4.53 backspace. took my stock 20's off. rides better, handles worse. truck just leveled in the front. you will get a slight rub at full turn when you hit even the smallest bump. now that they are half wore, they donnt rub at all.
4x4Wannabe
I been looking all day at rims, but does anyone run the stock rims with 12.5? if so, do they rub or will i need to get a spacer? and if I need a spacer will it be fine to run spacers on all the wheels so they stick out evenly
quietpeen
2021 TRX
Hellcat
You would need a 1/4" spacer to run 12.5 and even then there's is a slight chance that you would have rubbing
4x4Wannabe
Well what would be the biggest tire i could run on stock?
TheMaddog
DFW
Probably 34's. Stock suspension. But it'll rub, I think
