Rough country 5" 4x4 lift
Hemipig
Banned
MADDOG is a cuck
In the rear, it states that it uses 3" lift blocks. Is this like a body lift? Because my truck is already body lifted with 3" blocks. .
REAR
3in lift blocks
U-bolts
Hardware
SHOCKS
(4) Premium N2.0 series
FRONT
Lifted knuckles
Integrated sub-frame assembly
Differential drop brackets
Stinger bars
Sway-bar links
Skid plate
Bump-stop extensions
Hardware
http://www.roughcountry.com/dodge-suspension-lift-kit-381-20.html
blackbeautyhemi
Lewistown, PA
No these blocks go under the leaf springs to lift the rear. That's why it has new u bolts cause they're longer to make up for the block in between the axle and leaf springs. It'll work with your body lift.
H
Hemipig
Banned
MADDOG is a cuck
Thanks for the reply blackbeauty but my truck has a 2" block in between the leafs already, so those in the rough country kit would just take the place of those which is pretty pointless. I want to add to those 2" blocks not replace them.
I'm looking for used kits on craigslist and there are a lot of salvage regular cab 2002-2005 ram 1500 4x4s with lifts for sale. If I can get someone to sell.me their kit, will it still fit my 4 door if it comes from a 2 door?
