Rough idle, stalling, and jerky acceleration
Jon Shelley
Hey everyone first post here hope this is in the right spot. I have a 2011 ram 1500 5.7, 145,000 miles. Having a few problems that I can not dial in. First problem is rough idle and rpms dropping down to under 500 when stopped and back up to normal operating. Other problem is when under acceleration have pretty bad RPM surging the rpms drop and come back up and continue that until I hit a consistent speed. No check engine light for misfire or anything. Thinking it could possibly be the 02 sensors or fuel injectors. Have replaced spark plugs, fuel pump, and throttle body. Just trying to get some kind of ideas of what the problem could be instead of going to a mechanic.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
Vacuum leak? I’m having same problems but I found the intake manifold is leaking.. I tighten the bolts back down and still having the same issues. Or could be alternator. I’m having the gaskets changed out and also checking my alternator. Just installed new battery and starter, getting worse.
Razzman
Southern Arizona
2020 Limited CCSB
With a computer controlled vehicle it could be anything. Example, yesterday my son-in-law said his truck suddenly was jerking and wouldn't go up a hill, everything he said sounded like transmission issues. But i told him to go to a shop and check for codes, sure as hell it had some but not transmission, coil packs or spark plugs! $80 later he's back on the road and drives perfectly. Check for codes first before analyzing or asking opinions.
MrHayes
cincinnati, ohio
2016 Big Horn 4x4
I'm having similar problems with my new/used 2010 1500 4x4. Sometimes when coming to a stop and engine idles down it gets eradic and stalls. A couple of times it could have been dangerous. Transmission seems to run rough around 1500-2000rpm in drive with occasions of what seems like trans slip. I really need to get this resolved on next 10 days.
Razzman
Southern Arizona
2020 Limited CCSB
See post immediately above
scott lass 18
rocklin ca
2010 ram 1500
same mine at stop drops 600 rpm to 400 stops then jumps back up been trying things nothing yet ! the evap switch went bad replace po441 code wasn't the idle problem ! anyone really find something that fix it ! being told the ecm maybe bad need replacement ? gave to dealer they says don't see anything wow so stop and rpm drop stall then up 600 was told ecm problem really 250, to replace anyone try it saw on youtube it worked he said pretty sad stealers don't know either guess
