Rough Start and Idle
Keagan
Massillon Ohio
Magnum 5.2
Have a 98 5.2, its not starting well, i seemed like a dead battery at first but then driving down the road and let off the gas and it stalled. Took it home and looked around. cable to air filter compartment was disconnected so i thought that was it. but it still wont start well. if i hold the ignition on it will fire but stalls under idle. after a minute of giving it some gas it will stay running enough to drive but when i shut it off it does it again. and its getting worse and harder to start. Pleae Help!
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
You have a failing battery that is resetting the PCM, thereby making it have to re-learn where the IAC (Idle Air Control) valve has to position itself on the throttle body.
Keagan
Keagan
Massillon Ohio
Magnum 5.2
Thanks dodge dude, ya i started here then went to autozone and had it tested, new battery and its fine, was getting 250 cca out of 850.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Yikes. I'm surprised you had any power at all.
The truck should definitely run better now. I know mine did. Good to know all is well again. :)
