RPM surge
shelhamer72993
HEMI 5.7
When I’m driving the truck, every 3 to 4 seconds the RPMs surge about 50 to 100 almost as if it were going to change gears or something but even in 8th this happens. the truck thrust forward a tiny bit. It’s almost un noticeable, but I can notice it. No check engine lights and I just replaced the cam the lifters, timing chain, coil packs, and spark plugs. Diablo predator 2 tune with MDS delete kit.
Daw14
South Florida
Have you cleaned the throttle body ever ?
Check your intake manifold bolts , they should be torqued to 108 inch pounds. If it’s sucking air that can cause issues. This should be done yearly,as they tend to become loose often.
S
shelhamer72993
HEMI 5.7
Everything was cleaned when I did the swap. I’ll double check the manifold bolts but wouldn’t that cause a regular or sporadic RPM changes versus a consistent 3 to 4 seconds?
