Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
“water”… Im guessing you mean coolant.
Its either leaking or being consumed. Both are not normal.
1. Look for spots/puddles on pavement or splatter on underside of truck after a drive
2. Check your oil…does it look like chocolate milk?
3. Exhaust…Is it puking water or abnormal steam?
4. This one I defer to 6spd guys…trans fluid/coolant cross-pollenization?
Look underneath the truck for any wetness. Esp the bottom radiator hose. If there's a trail of coolant coming down the lower radiator hose (leaking down from the engine above) there's a good chance the water pump is leaking (soon to fail). Any coolant on the engine is probably a leaking water pump (coolant pump). There's a weep hole on the underside of the pump where coolant will leak out if/when the seal fails. And they all fail at some point. Pumps are a wear item. If it turns out to be the water pump (coolant pump), don't put a replacement off. Eventually it's fail dramatically and could possibly lead to bigger engine problems.
Or, like others said: Leaky hoses, leaky radiator ...or even a leaky heater core. Possibly a failed head gasket too. If you look in the tailpipe and it looks super clean (not very sooty), that's a good telletale sign w/o just by walking by the truck.
If you aren't the DIY type, a good mechanic should be able to solve the mystery of the missing coolant.
BTW, This wins the "best thread title ever" award! lol
