Sea Foam question
The Assassin
B-more careful, Murderland
Going to try this stuff out tomorrow. Just want to make sure I've got this right. 1/3 into the main vac line, 1/3 into the gas tank, and 1/3 into the crank case.
Is this correct?
LB3711
Trumbull, CT
3.6L V6
i do 1/3 thru the main vac and the rest in the tank. I don't trust the oil part. Wouldn't you have to do an oil change later?
adamwilkes14
As long as you keep your oil changed like you're supposed to, you shouldnt need it at all. I can see doing the fuel tank, but nothing else.
DrewRam
5.7L HEMI MDS
I'v done it in all three in the past. Just change your oil after if you put any in the crank case and you should be fine but like already stated you prob don't need to do that step anyway. I would let the vacuum line suck it up rather than pour that way you won't stall it out
After its all in turn your truck off and let it sit for a few, pouring the remaining in the tank. Be prepared for lots of smoke! Lol. When I used to do it I would go to an empty parking lot so I wouldn't **** the neighbors off :)
via DroidX (Tapatalk)
jhemi
wisconsin
i love seafoam i do all my vehicles atleast once a year but my truck i dont put in oil, other cars i use full can in tank, full in vacuum line about quarter let sit 5-10 min another quarter sit and so on for full can, and in older cars full in oil for 100 miles then change oil, and if there is a lot of carbon it will forsure smoke and i love smoking the neighbors out
RubberFrog
YES
You do an oil change after a hundred miles or so of driving.
RubberFrog
There ya go. 1/2 in the tank and half through the vacumn line.
Suck it into the vacumn line slowly so the truck doesn't die (a buddy helps here to work the throttle). When you get enough sucked in, let it choke out the motor (foot off the throttle). Let it sit for 10 or 15 minutes to work it's magic and then start the truck. Enjoy the smoke show! Try it at Carlisle and the guys around you will love you!
HungryHemi
Sorry for being stupid, but where can I find the main vac line on an 08' 5.7 HEMI?
ramhunter9
P-Star Jeep Wrangler
No question is stupid ..lol Welcome to the forum . One of our Hemi guys will chime in
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
This is exactly what I do. I don't trust the crank case part one bit and change my oil regularly enough so that I doubt I have any build up worth such drastic measures.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Frog ya should make another classic vid of this.
joetama
Ohio
We've got an '02 chevy express van that ran like total ****. Debated doing the seafoam, but went with the marvels instead. Last few oil changes we've got some nasty stuff out of it and it keeps running better and better.
Reticle918
