Sea Foam
wrigley
Anyone adding Sea Foam to the oil crankcase shortly before a scheduled oil change? Good idea, bad idea? 2023 5.7 HEMI.
Thanks
Mike
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
Thanks
Mike
Neither good Or bad. It’s stoopid.
Ask your warranty.
Ask your oil-refiner (no matter what brand you use) if their oil will address the issues and aftermath of a “flush” with SeaFoam.
Ask SeaFoam if their product meets the warranty-requirements of your vehicle for lubrication. Or cooling. Or corrosion-control. ..and ask your favorite filter-manufacturer if they’ve tested the efficacy and durability of their filters with snake oils. Ask for the test results.
OR…take a chance. (It may not be any worse than the stoopid 18-yr-old thing I did to my parents Dodge using kerosene.)
According to Google: A gallon of Sea Foam Motor Treatment typically costs between $60 and $80 per gallon, depending on the retailer.
A gallon of kerosene or diesel is less than $5.
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, 3.21 rear, 8-speed
Thanks
Mike
Skip the Seafoam, use something far better than most/any additive.
Look locally and find Valvoline Restore and Protect full synthetic. Use the 5w-20 if that is what your owner's manual calls for AND you are still under warranty. If you are outside the warranty seriously consider the 5w-30 version of the same oil. Start using this at your next oil change, and keep using it. Try to match it with a quality filter with synthetic media
It is very widely available so it's easy to find, and it is priced comparable to just about any other off-the-shelf full synthetic.
The lab reports on this oil show it is amazing.
Look up SDS anytime you ask the question and ignore brand. Is it a good idea to add a quart or pint of alcohol and oil to your crank case because that is what is in sea foam motor treatment. Putting it in a crank case just isn't remotely as effective as sea foam through vac lines which actually works. This process puts alcohol right to piston top 100%. See Chris fixes boroscopes. If you want a safe flush run Valvoline restore and protect for bottom of pistons and oil gally's and redline si-1 if you want top of pistons, or run sea foam the only way it should be run through vac lines.
jason1
US
It's great for 2 stroke small engines
ibike
Navy Badge
Tennessee
Running the restore and protect in my 2004 Jeep TJ. Wow what a difference it is making. I’m not a snake oil fan but with 210,000 miles on this engine the noise it used to make is gone. Just put it in last oil change and coming up on number 2 oil change. Just WOW!
wrigley
wrigley
Thanks for the responses. Just to be clear.......I have not used Sea Foam in my Ram. I have also never used it in any other vehicle. I recently came across a YouTube video that states using 1 oz of Sea Foam per quart of oil between 100 and 300 miles prior to your next oil change is good for reducing oil sludge build up. BUT..........I also came across a YouTube video that said good quality oils can also prevent oil sludge build up. I was just wondering if anyone used the Sea Foam and had good results. Thanks
