service light
rocket
Licensed Dynacologist
Pennsylvania
was 2006
was a HEMI 5.7
Got a serv 4wd light/chime. Can I rid this with the flashpaq 3865? I plan on doing the tranny and transfer case in the spring, so a winter prolly wont hurt anything. It wasn't mileage that set it off I don't think. 63113 is not usually a mileage set at the factory,lol. Coild I have other issue's? I runn 4x4 occasionally when it's wet out and at wot. Just too keeep it working, So to speak. I ran 45 miles in the slush with no issue's and I haven't been in 4x4 since last saturday. Any thoughts??:birgits_tiredcoffee
silverhemi10
mine just did this. they replaced the transfer case control module. seems to have fixed it
rocket
rocket
Pennsylvania
was 2006
was a HEMI 5.7
what was the price tag on that?
quietpeen
2021 TRX
Hellcat
Rocket his was probably done under warranty...lol.....did you check for any codes?
LB3711
Trumbull, CT
3.6L V6
um just check the codes you have. i bet its a sensor. you have a code reader ... use it LOL
silverhemi10
the dealer said it a warranty issue. they had 6 2010s come in this week with the same issue
rocket
rocket
Pennsylvania
was 2006
was a HEMI 5.7
yeah I'll check tommarrow, kinda beat right now. I'm too tired for beer, man that is sad........................:killer:
EJM05
Somers, CT
440 Big Block
Im too tired from beer too. lol. what has this world come to!?!?
HemiBabe
DFW
Hope it aint nothin too serious!
rocket
rocket
Pennsylvania
was 2006
was a HEMI 5.7
****! my sc is locked! WTF! I swear I must of been a mass murderer in a previous life, I have the worst luck!
my sc keeps reading, tuner locked in recovery node, then it cycles thru erasing and retuning god knows what! I just went thru 3 cycles, all the same ****! no other choices are given. I can't even data log! ( I plugged in while running) still in locked mode.
Scott are ya listeneing?!?
LB3711
Trumbull, CT
3.6L V6
Can't help you there. Mine wasn't as fancy as yours. Mine was locked too but it needed to be upgraded.
Sent from my tapatalk equipped AT&T iPhone 4.
rocket
rocket
Pennsylvania
was 2006
was a HEMI 5.7
Well I upgraded,and had a customised tune ,after the upgrade. it went back too locked?! Upgraded again and still locked. I'm sending it back; prolly end up buying another one. :(.
