Shaking
Allen1415
Cincinnati Ohio
Recently, within the last couple months I had a zone 6 inch lift with 22 inch rims and 325/50 tires installed. Dealership said tires are balanced and alignment done. I received alignment paperwork. My rear end at 60-75 mph is now shaking like Miley Cyrus, and my truck is pulling left. My truck is a street Queen and has never seen dirt. Beyond having tires rebalanced and another alignment done what could be happening?
Ive always felt a little wobble but nothing like what is going on now. Also the roads/highway around Cincinnati are just trash so I can't hardly ever tell if it's the road or my truck.
Thanks
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Thanks
Check out an adjustable trackbar. There are a few options out there to choose from. I use Core 4x4 myself for the trackbar and rear control arms. That will keep your rear axle planted and Miley can go home :D
The big long red bar and has the silver handle is what will keep your axle from wobbling.
Wallyb4
Retired EWC(SW/AW) 1983-2003
Virginia Beach
5.7L
Once you raised the veh , the rear axle became out of square with the veh. The adjustable trackbar will correct your problem.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Thanks
What kind of tires do you have ? Some tires just don't balance good ...
JasonK94Z
Anderson, SC
I’m going through the same thing. Around 70-75 it shakes but sometimes goes away. At 80+, it smooths out. It’s really weird.
Not lifted, just leveled.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
If it smooths back out it’s tires. Rotate them and see if it improves. Road force and hub centric balancing are the 2 best ways that most tire shops don’t use
A
Allen1415
Cincinnati Ohio
So at around 80mph it does smooth out. The tires I bought we're nitto ridge grapplers. The lift relocated the stock track bar above the axle.
2018 2wd
How often have you rotated them ? Because MTs and hybrid tires really are not meant to be driven daily they need to be rotated pretty often and consistently .... My Ridge Grapplers are wearing out pretty evenly but just recently I do get a small vibration but because I haven't rotated them like I have in the past .... I am over by like 1k miles on the rotation
Take them to get re-balanced with as little weights as possible ... a good shop will know how to do so and definitely road force balance them ...
JasonK94Z
Anderson, SC
I do have hub rings, but they are plastic ones. They’ve been on the truck for probably 7 years now though. The truck was fine until I got the tires rotated and balanced. Old tires had one with a flat spot from sitting parked for months. Bought new tires and still same thing. I’m beginning to wonder if my hub rings are screwed up.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
or the shop didnt put your hub rings back. Ive seen that more times than im comfortable with
joshhhh
