shallow mount subs
ramhunter9
ramhunter9
P-Star Jeep Wrangler
ok now Mr audio has chimed in ...... what makes them crappy ? have you had expeariance with them ? and yes this was directed to you AF .
DisturbedGator
shallow 12's arent even as good as regular 10's. the only time shallows are ever good is in a regular cab where space is extremely limited. the only thing a shallow sub is better than is regular speakers.
RH do not get shallow subs. you have the room to get regular ones...do it right. shallows dont put out near the range or volume regular subs do.
sorry to disagree, but i had regular 12s, and these shallow 10" p3s sound ten times better and crisper in my quad cab.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Dave can give us his thoughts........LOL - the sub should be there tomorrow or Saturday. :D
ramhunter9
ramhunter9
Looking forward to it jj .
And my amp is a kicker zx350.2
i think i can run 2ohm with it .
Now do i bridge that 2 ohm ??? Thats the question
quietpeen
2021 TRX
Hellcat
that could fall under the argument of which sounds better a 10" or a 12" sub...LOL
quietpeen
2021 TRX
Hellcat
you definitely want to bridge the amp, the question is do you wire the sub in series or parallel to get it to a 2 ohm load. I think its parallel
ramhunter9
ramhunter9
From the diagram i have its like this ....positive incoming to sub ..jumper to other positive post .
Naeative incoming to sub ...jumper to other neg post
ramhunter9
ramhunter9
LIKE THIS ??? WITH THE AMP BRIDGED ??
ramhunter9
ramhunter9
10 - 4 this is going to rock .....come on mail system !!!!
quietpeen
2021 TRX
Hellcat
it should....how many watts was the amp pushing at 4ohms? about 175watts?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I hope it gets there tomorrow............I would think its a 1 day trip?
ramhunter9
ramhunter9
RMS Power Range :
* RMS Power @ 4 Ohm: 110W x 2
* RMS Power @ 2 Ohm: 175W x 2
* RMS Power @ 4 Ohm Bridged Mono: 350W
IT DOESENT GIVE ME SPECS ON 2OHM BRIDGED ?
I WOULD THINK 2 OHM BRIDGED WOULD BE 350 PLUS WATTS ?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
well........**** - I just noticed that the manual says "minimum 4ohm in bridged mode"
that is bunk dude. buy Butch's 400.1 :D
quietpeen
2021 TRX
Hellcat
RMS Power Range :
unfortunately that means that it is not 2 ohm stable in bridged mode. I've read its not good, but you could hook up just one voice coil...LOL
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
wait........can't you run 1 channel to each voice coil? or am I just stupid tonight?
ramhunter9
ramhunter9
Now im confused .... So i can run 2 ohm witch will give me the most rms but only on one channel ??
If i were to bridge it on 4 ohm what will give me the most power ?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
2ohm will give you the most power. BUT, it seems that the amp won't do 2ohm in bridged mode.
4ohm bridged.......won't work with the amp, as its a dual 4 setup. you can get 2ohm or 8ohm from it.
you can't hook up only 1 coil on a dvc sub either, thats not good.
ramhunter9
ramhunter9
Ok ok now im really lost .... Tell me how to hook this ***** up lol
CANT I JUST BRIDGE IT ON 4 OHM TO GET THE 350 RMS ?
Marty424
