quietpeen
- Joined
- Jul 14, 2010
- Posts
- 25,443
- Reaction score
- 3,913
- Ram Year
- 2021 TRX
- Engine
- Hellcat
so wire that bad boy at 2 ohms then ?
yes, if your amp is 2ohm stable you definitely want to wire it that way.
shallow 12's arent even as good as regular 10's. the only time shallows are ever good is in a regular cab where space is extremely limited. the only thing a shallow sub is better than is regular speakers.
RH do not get shallow subs. you have the room to get regular ones...do it right. shallows dont put out near the range or volume regular subs do.
sorry to disagree, but i had regular 12s, and these shallow 10" p3s sound ten times better and crisper in my quad cab.
Looking forward to it jj .
And my amp is a kicker zx350.2
i think i can run 2ohm with it .
Now do i bridge that 2 ohm ??? Thats the question
RMS Power Range :
* RMS Power @ 4 Ohm: 110W x 2
* RMS Power @ 2 Ohm: 175W x 2
* RMS Power @ 4 Ohm Bridged Mono: 350W
IT DOESENT GIVE ME SPECS ON 2OHM BRIDGED ?
I WOULD THINK 2 OHM BRIDGED WOULD BE 350 PLUS WATTS ?
Now im confused .... So i can run 2 ohm witch will give me the most rms but only on one channel ??
If i were to bridge it on 4 ohm what will give me the most power ?
