USPatriot1776
For about a week or so now my SiriusXM has disappeared from my media. I've tried soft resets (battery disconnect and fuse pull) and nothing seems to bring it back. Any help or insight would be appreciated!
If you are removing power from the radio frequently this is expected behavior. It needs several hours/power cycles to appear again after removing power from the radio. If it has been over a day and the vehicle has been run and left to sit several times over that day that should be enough for it to reappear.For about a week or so now my SiriusXM has disappeared from my media. I've tried soft resets (battery disconnect and fuse pull) and nothing seems to bring it back. Any help or insight would be appreciated!
No the whole sub menu is gone for XM, I pay 12$ a month for it recurring on my card so it isnt that. I can still access it if I use the mode section in alfa obd under radio -> radio navigator module. All be it temporary but can still access it none the lessdoes channel one even come up ?
Do you still have the original radio installed ?
Is it time to make a payment ?
I let my Sirius XM expire ,because i am not doing any trips, so i am staying Locally & i can continually listen to local FM stations
