Slight things wrong...
iLLeStEyECoN
Tamarac
HEMI 5.7
When everyone’s mirrors are folded in are they right up against the glass also?
Yes. They actually bump into the glass when they close. Are they not supposed to?
rrjjpp74
SW PA
Not sure if they are supposed to or not. Was just wondering if it was just mine or not.
RamCares
n/a
n/a
I’m using this as a way of compiling things as we find them not being as they should. This is not a complaint but rather a way for others to add if they also have this situation.
To start I’m at 1500 miles and the two things that happened are, my brakes are squealing and my ambient light housing under my pass front seat is dangling. Now I’m scheduled on Monday to see the dealership for another situation so at that point I will bring up the other (2) things. I’m loving what the truck has to offer and I know with new production comes new world problems lol.
Hi DRkNESS,
If you are in need of additional assistance while your Ram is in service at the dealer, please send us a PM. We are happy to help.
Darlene
Ram Social Care Specialist
DRkNESS
DRkNESS
South Jersey
Well thank you kindly, but I’m going to give them a chance to take care of this first. I’m definitely not complaining, just posting a section where as we find we encounter things, others can add or give advice as to what was done to resolve this. :)
iLLeStEyECoN
Tamarac
HEMI 5.7
Hi DRkNESS,
Darlene
Can you confirm if the side view mirrors are supposed to knock into the glass and remain against them when folded in?
RamCares
n/a
n/a
My mirror does the exact same thing. Sounds horrible too, its been at the dealer once for this and they have yet to resolve it. I go in next week.
Hello dozer327,
I understand your desire to reach a solution for this. If you want to get a case started on this before you head back, let us know. We're available via direct message if this is of interest.
Jasmine
dozer327
Pittsburgh, PA
2019 Ram Laramie
Hello dozer327,
Jasmine
Jasmine,
I already have a case started with FCA on this. Its going into the dealer next Tuesday.
Accountant
CA
Laramie Hemi 5.7L
Im having the exact same problem as well.
Seems like its the remote that causes it. I've only done two push button starts and the new them (Ram 3) has stuck, so far...
Check that, when I did a push button start for the third time, the dash display reverted back to default theme but main console was still on Ram 3. SMH oh and my air ride was in aero mode LOL. I always keep in in normal. Need a bug fix
MarvinK
Pullman, WA
HEMI 5.8
Any chance this is tied to the key fob? I'm pretty sure there's a setting that says to tie preferences to each key.
mhb1638
Savannah, Georgia
When it rains, auto wipers kick on the headlights (which it should) but makes it go to night mode headlights. Way too much bass in speakers causing vibration throughout doors and rear wall (set to -5).
Flot
I believe my driver's side mirror hits the window when folding, but passenger does not.
I have not had an issue with the theme not persisting between starts, either in the car or by remote - however I do only use one of the keyfobs.
Mysteriously when I remote start, about every third time it honks 3 times instead of 2. I assume that I have not suddenly forgotten how to lock my doors, so I'm a little concerned about this.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Only issue I have seen/heard is squeaking on the bench seat console if I place my arm anywhere but dead center on the console.
Doesn't bother me, but bothered the wife when I did it 10 times in a row to get a reaction lol.
LOL, that would be my signature move everytime my wifff got into one of her rants... :fca5278d:
UH60Hwkdrvr
Alabama
My media display occasionally locks up and will not function until the vehicle has been off for 5 or more minutes or the display screen will go blank.. I have a 60/40 rear seat with the recline feature. The 40 seat reclines just fine, but the 60 seat does not function. I have air suspension and sometimes the vehicle will not return to normal ride height after being in aero mode. I have generally found all of the tech to be buggy!
Mike
iLLeStEyECoN
Tamarac
HEMI 5.7
I have been trying to figure this out. My Charger had auto headlights with wipers but did NOT dim the interior if there was sunlight outside. The RAM reverts back to the old way and does dim the interior which makes it hard as hell to see in these South Florida sun showers.
I remote start almost every single time and have not had this issue.
MarvinK
Pullman, WA
HEMI 5.8
I wish there was an option for the mirrors to tilt down, but a lot less then the current option. It’s not wrong, I’d just prefer less tilt.
MarvinK
Pullman, WA
HEMI 5.8
I actually turned that feature off in my truck.
I’ve been going back and forth. I like seeing the parking stall lines, but I also want to see more than the ground. I have them off but would use them if it was slight instead of dramatic.
DRkNESS
DRkNESS
South Jersey
On my Accord, just my passenger goes down and that I like. With this Ram it’s like it’s trying to look up under the truck while I’m backing up.
Immerge
