Smaller wheels bigger tires?
JFD3
Hellertown, PA
5.7L
Hi all. New to the site and thanks in advance for your help.
I have a 2014 1500 sport crew cab 4WD with 20” wheels and 275/60-20 tires. No lift or leveling, totally stock. I want to switch to 17” wheels but I’m considering increasing the tire size (overall diameter compared to what I have. My question is what size tires can I put on 17” rims that won’t rub and without any suspension modifications, etc? Do I need any offset and how much?
kurek
Northwest
This is absolutely a question somebody has asked once or twice before :D
285/70R17 is tried and true. Bigger can work, search function strongly advised.
2017 Rebel. I went from 285/70-17s to 305/70-17 with no issues.
A Rebel with the conventional coil spring suspension has a higher ride height from the factory vs the Sport trim truck, could make a difference.
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
The Rebels with air ride are the same way. They achieve that extra inch of ride height essentially by using the first off-road mode on the non-Rebel trucks with air ride. My Limited has air ride but my OF1 mode is NRH on a Rebel. That’s why Rebels only have one off-road mode and the other trucks have two, one for inch higher and another for two inches higher.
I don’t know how they achieve the higher height on the spring-ride Rebels.
corneileous
Podunkyville, OK
