Spark Plug change
DKNIGH2
Adirondacks NY
2014 3500 SRW
Bought my truck used and just changed the plugs this morning. Truck is 2014 crew cab long bed with the 6.4 hemi. Not sure of previous maintenance so figured it was a good idea. Most came right out no problem. A few different size extentions and a 5/8 plug socket. 10mm for the coil packs, a bit of dielectric grease and some anti seize for the threads. One or two needed a little more effort. One I was afraid of breaking so some pb blaster then let it sit while doing another. After a few minutes it too came right out. By the looks of them they were original.
All in all not a bad job and only took a couple hours with a few breaks to check on the brisket in the smoker !!
