Spark Plug ?
bereta1
Ky
I have a 2016 Ram 1500 5.7 Hemi. Just purchased a set of NGK plugs LZFR5C1-11 to replace the oem SP143877AB. Just checking to see if they are the right ones.
B
bereta1
Ky
I was told they were, just making sure. Thank
Hopefully you didn't buy them off Amazon or Ebay,if you did return them and buy from Rock Auto / a brick and mortar auto parts shop or the dealer.If you bought off Amazon or Ebay,they're fake/knock off NGKs and could cause you issues,especially if the porcellin or tip exit the plug and get jammed under a valve
QwikKota
5.7L
*always, always check gap. There are countless people who have had "pre-gapped" plugs way out of spec, fresh out of the box. Always check.
There are plenty of people testing plugs that have bent electrodes or large gaps and they still work fine. It's not worth the risk damaging the center electrode or the porcelain insulator. A full set of plugs for the Hemi is quite expensive, IMO.
QwikKota
5.7L
To properly check the gap you have to force a tool (feeler gauge, wire gauge, etc.) between the iridium plated electrode and the ground electrode. That can cause damage. If you are just floating a tool in there and not touching the center electrode, what is the point? You are just guessing with that method.
KenR 955
Greater Knoxville TN
Negative Ghostrider.
Using a gapping tool you adjust the gap by lifting the ground arm from the point where it curves from the side of the plug where it is attached to the side of the plug.
I will find a video to attach in a minute.
Go to the 1:05 minute mark.
QwikKota
5.7L
I am talking about measuring the gap. If you are not touching the center electrode you are not getting an accurate measurement. I would just check them over for any damage and way too small or way too large of a gap by eyeballing them. Install as is or return if they look way off.
RamDiver
Marlborough, Ontario Canada
2021 DS
With that kind of logic, why even bother with the P/N?
That is very bad advice.
I'd sooner break a plug or 2 than use the wrong gap in my Hemi but gapping plugs is not rocket science.
If one is inexperienced, take the old plugs and test your gapping skills before touching the new ones.
If the new plugs are perfectly gapped, there will be next to no stress on the surfaces to drop a gauge in the space.
turkeybird56
Central Texas
DITTO 100%%%%%%%%%%%% ref check gap. Only takes a few seconds to verify gap. Cause even (1) bad one in a group of 16 is no bueno.
Sherman Bird
Houston, Texas
It all depends on where you bought them. Many on-line places sell counterfeit parts, and this is true of NGK spark plugs, as well.
turkeybird56
Central Texas
You're providing bad advice.
I'd sooner break a plug or 2 than use the wrong gap in my Hemi but gapping plugs is not rocket science. If one is inexperienced, take the old plugs and test your gapping skills before touching the new ones.
If the new plugs are perfectly gapped, there will be next to no stress on the surfaces to drop a gauge in the space. WTF Man?
^^^^^ DITTO ^^^^^.
Sounds like the joke a moola guy from behind the parts counter. Heard a few of them and their BS at the auto store one day, and I just about broke out laughing. I am no mechanic, but turned a lot of wrenches when I was young, to my Mother's angst.
Heck, I check the gap before putting plugs in my lawn mower. Just saying.
ALL IMHO.
B
bereta1
Ky
Mine came from Rock Auto. Just had mine verified by NGK. Sent pics to rep to authenticate. All good thanks
BenchTest
Midwest
There is a difference between CHECKING gap and damaging the electrodes trying to adjust the gap... If the plug doesn't meet spec, exchange it with the retailer. Gap exists for a reason.
BenchTest
Midwest
I replied to your prior comment, but after reading this, it's clear you don't know how to use the tools required to check gap. There are Youtube videos that explain how...
BenchTest
Midwest
Eyeballing them? Got it. Do you use ugga duggas when tightening your lug nuts as well? 3 or 4 ugga duggas for you? I prefer 4 just to make sure. If it's Sunday, I use 5 ugga duggas. Smdh...
The electrodes aren't made out of crystalized fairy tears and crumble if you look at them. They will tolerate a feeler gauge or calibrated wire passing over them without any damage. It's almost like they are designed for that or something... Just don't be an ignorant wrench when you're doing it. Use the necessary cautions and all will be good. Again, check out Youtube sometime. They have quite the selection of videos.
